DRSMPSExplorerJul 31, 2014Replacing P series with LT on a 1500 SierraMy 1500 series Sierra came with P265-65-R18 from the factory. The tires have been OK, but I've always found that when loaded (even with the WDH) the steering is a bit loose. In speaking with others ...Show More
ktosvExplorerJul 31, 2014Do you tow with your tires at 35 PSI? If so, try towing with them inflated to the most likely 44 PSI to achieve the max load rating.
Related ContentKWIKEE STEP MOTOR REPLACEMENT SERIES 32Kwikee series 32 step replacement Motor & GearboxGMC Sierra EV DenaliGMC Sierra EVWater Heater Replacement Recommendations
