monkey44's avatar
monkey44
Nomad II
Feb 28, 2019
Replacing Shocks - How much time.
Assume you have all the tools, AND a hydraulic truck lift --
Is it easier to remove tires or does that matter?
How much time does it take to change four shocks on a Chevy 2500HD.
We're removing stock shocks and installing 4600 Bilsteins ... all four.
  • rhagfo's avatar
    rhagfo
    Explorer III
    I put on the 2001 Rams 5100 in a tight garage, no jack wheels on in about two hours. Truck lived in the PNW zero corrosion.
  • monkey44 wrote:
    No corrosion - Visit the Cape now, but live in Florida - this truck was bought in Florida and lived here most of its life ...
    I'm just trying to plan the time so SIL can come over and give a hand. :)
    Saturday at 10 AM, with a six pack for 3 PM and you should be in good shape.
    :R
  • No corrosion - Visit the Cape now, but live in Florida - this truck was bought in Florida and lived here most of its life ...
  • Turtle n Peeps wrote:
    No rust; an hour to an hour and a half. Rust? Days to weeks! :B
    And you are in Cape Cod, even if not for the winter, you will likely see some corrosion if the truck is over a couple of years old.
  • Do a youtube search for pictures and sometimes some dang good tips for your particular year/model GM truck.
  • All depends on the vehicle. Some trucks front ends have coil over shocks which will take a lot longer. I've done rears on my trucks with never lifting or taking off the wheels just crawl under unbolt them and bolt the new ones in a half hour job at most for the rears.
  • A few hours. You can leave the tires on, just crank the steering wheel to one side for access. Spray the bolts with PB Blaster.
  • Using a floor jack and air tools, less than 2 hours to do all four replacing with Rancho 9000s on a 2015 2500HD. Easy job. Definitely take off the fronts.
  • I never timed myself but on the fronts definitely remove the wheels, make it easier.
