Aaron, I have been busy coating everything with 303 including the fiberglass. The plastic flange around the window in the bathroom is one you should keep an eye out for, the toilet paper holder, the toilet and even the plastic on the jacks. They will all turn yellow over time. Even the skylight in the bathroom needs attention so it will always stay clear as eventually it will become blurred out. That fan vent is a huge pain to get open. I can't reach it from the ground and had to open the galley window and could only reach one tab. I just use the fantastic fan in the cabover to suck out the air when cooking. I would replace the vent if you want something easier to get open, otherwise just paint it. I find it hard to believe you wax or some other chemical will get the yellow out. On my 2012 WC it turned yellow and while buffing the sides my buffer hit the thing and shattered it.
303 is the bomb
You don't want this turning yellow
Good luck
Nolan
