Robmoo
Apr 08, 2018Explorer
Replacing water heater with DSI
The pilot light for the water heater on my 2001 Coleman wont stay lit. I replaced the thermocouple and no dice. So the issue must be the gas valve. Rather than buying a $150 replacement valve I'm going to buy a new Suburban 6gal DSI model. It looks like I just disconnect the water and gas, removed the outer door, slide the old one out and slide the new one in and reconnect. There is wiring near the old unit so connecting the DSI system shouldn't be too much work. The valve for the gas is off at the tank, so I shouldn't have as much gas in the system to bleed off as I disconnect the gas.
Is there anything it would be useful to know before I start this project?
