waynefi's avatar
waynefi
Explorer II
Jul 31, 2019
Replacing water tank
My fresh water tank has a leak, so I am trying to replace it, but I can't figure out how to get the old one out.
There are two side-to-side rails in the front and rear of the tank. The back one is screwed into the trailer frame. The front one looks more permanent. There are two lengthwise rails that have tabs that drop into slots in the sideways rails. So the obvious thing is to lift the lengthwise ones, then slide the back rail back. But I can't lift the tank, because it is up against the bottom of the trailer. I can't move the back rail with the tabs still in place. So how do I get the tank out?
Has anyone else seen this arrangement?
  • Unbolt and remove the long side to side rail, then remove the 2 short front to rear rails from their slots while supporting the tank. The tank should then slide off the other long rail allowing it to drop down. Make sure to disconnect the tank hoses so you can remove the tank.
  • newman fulltimer wrote:
    Take the bolts out the rails swing down tank drops out . save a lot of time and go to harbor freight get a plastic welder and weld the crack shut
    The rails are sitting on top of the I beam, so I don’t see how they can swing down. However, the plastic welder might do the trick.
  • Take the bolts out the rails swing down tank drops out . save a lot of time and go to harbor freight get a plastic welder and weld the crack shut
