Gjac
Dec 16, 2020Explorer III
This has been very informative to me and have formed some conclusions based on your comments. Most people reported that a WDH or anti sway bars are not required for a 3500 lb or less TT. I have no problem backing a 19 ft boat down a ramp so I can't see a 19 ft TT being much harder. As far as ride quality after reading on this forum all the handling issues of the F-53 chassis and these short 24 ft Class C with light front ends a truck and TT combo should ride better. One thing not mentioned a lot on here, is each tire carrying the same load for a good ride. My old P-30 chassis has this and I drive it with one hand like a car even with passing trucks without all the suspension addons people buy to fix the ride. My only concern was the added tongue weight from the TT causing the front end to be lighter. Only one person said a special HD package was needed most said any 1/2 ton truck would be fine. My right arm is still good so I can crank the tongue jack on my boat now, not sure how much different the TT would make. As far as leveling it would appear easier than a small C because you only need blocks for one tire vs 3 for a C(one for front tire 2 in rear for dual wheels). I fully realize setup was going to be more difficult than my Class A with auto levelers and in over the last 15 years and 100k miles I can only remember a few times setting up in the rain, because when it was raining it was much easier and safer just to pull into a WM for the night than to pull into an unfamiliar CG in the dark. So have I come to the right conclusions am I missing anything?
