opnspaces
Aug 07, 2021Navigator III
Dicor would work for al your questions.
In the Thule rack I would use a small pointed object and pick the old sealant out. Then you can reapply Dicor sparingly over the screws again.
On the membrane cracks I would probably use Dicor over them. Eternabond would work too. But be careful and let it lay without tension. Don't pull it tight around the corner or it will loosen up over time and leak.
For the rest of the screws you can either pull them one at a time and reseal them. I just looked at 3m 4200 and it seems like a good candidate for what you're asking.
