d3500ram
Aug 01, 2021Explorer III
If it were me, I would remove, inspect and reseal. If you have a leak on a camper in which you do not know the history then it may also be that you do not know what is going under the roof components.
If you had a leak at one time (even if it is sealed now with whatever method) you still may have a ticking time bomb. What I mean is that depending on how much moisture got in, there could be potential for damage.
I bought a 2 year old camper in brand new condition in 2010 and I religiously maintained as best I could. Yet still there was an instance where water unbeknownst to me got in somehow. I discovered it some 6 years later coming in the adjacent vent when doing maintenance around the shower bubble; I ended up replacing and sealing both using eterna-bond where I had to cut back some of the roof membrane, butyl tape and dicor:
Before:
After:
Before:
After:
