HMS Beagle wrote:
While I like AGMs, I advise against them unless you upgrade your charging system over the usual OEM system. AGMs require more carefully controlled charge voltages, preferably temp compensated. Charging them with the cheap equipment normally installed by an RV factory will bring them to an early death.
Can you name the brands of converters that RV mfg's install that would bring an AGM to an early death?
Progressive Dynamics, a good working WFCO, Iota w/ DLS, Boondocker and many more do just fine charging our AGM's.
I and many of us will disagree with your statement. Pd series and many others do fine with no compensation. Many of us have YEARS on our AGMS with non compensated converters and still performing just fine.
Jim
