trail-explorer
Mar 14, 2019Explorer II
Vintage465 wrote:
Since I do mostly boon docking and cant stand the sound of generators I'm in the Gas Refer camp. Any solar I have is going to keep my 4 each 6v batteries up so if it gets cold I and need to use the furnace, I can. Personally I don't see the day when I go to a 110v refer for camping.
DITTO.
I don't mind a generator for occasional charging, but with a residential fridge, it's likely you will need to run the generator several hours every day (and listen to the noise of said generator).
WHat happens if the inverter fails? then your fridge is kaput unless you have a generator to run non-stop until you solve the inverter problem.
44,071 PostsLatest Activity: Aug 30, 2026
