theoldwizard1
Jul 16, 2018Explorer II
dodge guy wrote:
Wizard was recommending NOT running the fridge while underway.
Any decent householfd refrigerator should hold temperature for 8 hour IF YOU DO NOT OPEN THE DOOR !
dodge guy wrote:
... I think for most of us using a residential fridge and starting with a fully charged battery it will work just fine, and even better with 2 batteries. And the truck will keep it alive long enough till you plug in at the next stop. And to really extend it with no worries you could run a good solar panel.
Concur, but it depends. What voltage does your inverter shutdown at, what voltage is delivered from the TV to the RV batteries/inverter and will your inverter automatically restart after a low voltage shutdown.
If you are dry camping and do not want to run your generator the read this about DC-DC charging while you are driving.
44,068 PostsLatest Activity: Jun 05, 2026
