theoldwizard1
Aug 07, 2018Explorer II
seaeagle2 wrote:
If you're talking about a tankless residential water heater, they require 110V, (no biggie), they are 199,000 btu, so usually requiring upsizing a residential gas line to 1", I'm not sure how long a RV sized propane tank could supply enough propane for 199m BTU.
Rheem make a couple of different models. They do require 120V AC for ignition, but the installation guide says only 1/2" gas pipe is required (the one I linked is 160,000 BTU).
Shipping weight is 54 lbs. There is quite a bit of plumbing (hot and cold water, gas, electric, PT valve outlet, etc.) below so I would want some kind of cover for all of that.
