Huntindog wrote:
My thoughts:
If it's not safe to use for a nap, then it's not safe to use period.
If it is staffed, then it is likely safe.
I doubt that anyone is starting a "clock" when you pull in.
So long as you are inconspicuous, I doubt you will have a problem.
These rules are probably in place to give the staffers the ability to "deal" with problems, such as the pimps, hookers transients etc.
I would just use the facilities in "stealth" mode, and see what happens. I bet nothing.
Exactly...I even said I have never seen a trucker get kicked out either.
But for some reason the MODS deleted my post for no reason...
