69_Avion
Oct 07, 2013Explorer
LaytonLad, welcome to the forum.
Check out http://repairingyesterdaystrailers.yuku.com/directory#.UlM_db7n_IV
As far as showers go, I would consider putting a LP "Tee" in the propane line (after the regulator) to hook up a quick disconnect so that you can use a Camp Chef outside water heater. Then all you need an outside hose bib tap off of your pump. Then you just take a shower tent with you. If you make sure that your frame of your trailer is strong enough, you can add some water capacity. You won't want to use an old fresh water tank.
I'm looking forward to your restoration.
