LaytonLad
Oct 11, 2013Explorer
Thanks for the ideas and links. They really do help.
Please feel free to add any pointers. Its greatly appreciated.
So heres my plan of attack. As you can see from the picture below I have abit of work to do. There are several areas that will require the entire floor to be replaced. The frame needs some work as well. The left side of the frame isnt so bad. The is some here and there but 90% of the frame is in good shape. The right side will require a complete redo. I am thinking that I will need to remove one part of the trailers frame at a time. Then rebuild one at a time. I should say that I would build the frame on a table, place it off to the side then do the next. I would just do the pieces that is needed if the entire frame didnt require a redo. Once I have all the sides completed I can redo the floor and then rebuild the frame.
