wmoses
Sep 29, 2013Explorer
Hahah ... nice one, bumpy. :)
I still feel that having a sensor is better than not having one, since listening to the wind manhandle my awning (on the previous RV) was the main reason for a crappy sleep when there is a nice thunderstorm outside. That manual awning had a nice triangular structure since the support brace was connected back to the trailer so it was very strong, and that is why i never go a failure even though the noise was a bit unsettling. With this "kneeling" type arm, it seems that even a slight breeze would cause the awning to "bend at the knees" as it were, and slacken the awning itself. I do know about the awning support poles and tying the supported awning down to the ground, but that is another discussion.
Also, as many have pointed out (elsewhere) one could leave for a side trip in great weather with a good forecast and have the weather change at the trailer without you even knowing. Or even if you routinely do retract the awning every time you leave, you could forget to do so once in a while. Murphy's Law dictates that is when the wind will come up and ruin the awning.
David - I note that you are an RV tech, and it is great to have your input. When you said "I would do a little more research ..." do you mean you (David) would do some research using your professional connections, or do you mean I should do this research?
Looking at the package I got from Forest River - there was not even a photocopied piece of paper for the awning! Whose fault is this I don't know. I have since gone to their website and downloaded a 4-page user manual, 3 pages of which were useless. There is nothing on the wind sensor and where it can be fitted or how it can be fitted. In the link I provided above in my initial reply to you, there is a table that suggests that the 9100 awning could have a wind sensor. If as you say there is a control box, then there must be some 9100 awnings with and without control boxes ...? That said, it does seem improbable that simply plugging in the sensor in-line at the top of the forward awning arm would add this functionality.
Still looking for concrete affirmation of what is needed.
Also looking for feedback - positive or negative - from users with wind sensors in their awnings.
44,068 PostsLatest Activity: Jun 10, 2026
