transamz9
Oct 04, 2016Explorer
Your truck plug has a dedicated ground and that is the bottom left blade when you open the little flap on the truck. I would run a dedicated ground wire to the trailer plug. Everything on my boat trailer has a ground wire that is connected to the plug. If I'm not mistaken, some lockout solenoids only have a power wire and ground through the brake line. You might be able to take a Stainless hose clamp and clamp a wire to the brake line close to the solenoid and tie it in that way.
44,056 PostsLatest Activity: May 04, 2014
