AnEv942
May 27, 2017Nomad
The distance between the pivot holes and slots the resting pins set in of the bracket is slightly more than the distance of the steps corresponding pivot hole and mounted pin... if that makes sense. Causes the steps, if fully collapsed, to open a bit when rotated into bracket. I played with mine thinking I mis-assembled something before I started measuring.
The cable on the rear of steps to keep stairs from unfolding wouldn't address.
Actually if forcing to stay fully collapsed pins wouldn't go into bracket slots. I don't use cable with the Stow N' Go bracket.
If it takes that much force to fold suspect one or more of the pivot bolts too tight. I readjusted mine, never tried lube.
44,071 PostsLatest Activity: Aug 30, 2026
