wnjj
Jul 07, 2013Explorer II
HMS Beagle wrote:
The Torklift literature talks about the half covered hole method of tensioning. My problem with the O ring is that you have to keep messing with it: turn out a couple of turns, roll the O ring up, then try again, etc. The hole is much quicker to look at. The O ring is a nice check on it though.
Exactly. The hole method is super easy and the o-ring just confirms after you latch the handle if you don't trust it. From half-covered hole to locked will always stretch the spring the same amount and you can see where you are at without applying any force,
