ShinerBock's avatar
ShinerBock
Revmax 68RFE Transmission Cooler Thermostatic Bypass
My re-builder recommended this upgrade when I had my custom trans built. I have been running it for several months now and finally had a chance to tow with it in. All I can say is wow. This is a must have mod for those who tow with their 68RFE even with a completely stock truck if you are seeing high trans temps.
Those that own a 68RFE know that it is notorious for running hotter than most other transmissions. I used to think that it was due to design until I replaced my thermostatic bypass valve with this Revmax one which is advertised to improve flow to the cooler by over 80% and decreases trans temps by as much as 50F. I can attest that it decreased the temps by as much as 30F empty and 20F towing in my truck.
The stock one purposely reduced flow to the cooler in order get the trans temps hotter quicker in colder weather. The problem is that many times it gets stuck or partially stuck in this closed position causing temps to spike inside the trans. Not only that, but the stock valve itself is a very restrictive bottleneck. My re-builder started recommending these bypass valves after seeing several of them fail causing the transmission to fail.
68RFE Transmission Cooler Thermostatic Bypass Upgrade
  • ShinerBock wrote:
    IdaD wrote:
    What temps were you seeing when you were towing stock versus now? My truck is totally stock and I've never had problems with the trans overheating.
    Mid 180F depending on outside temps. It is not uncommon to get up to 110F here in south Texas. It is also very intermittent too. Sometimes it will go passed 175F and towing the same trailer in the same conditions another day will never even get to 175F which leads me to believe I may have had a valve that was partially stuck every now and then. Now it stays in around 160F when towing.
    Interesting. Mine seems to consistently run around 168 towing regardless of outside temperature.
  • What temps were you seeing when you were towing stock versus now? My truck is totally stock and I've never had problems with the trans overheating.
