LeichardtiExplorer IIINov 28, 2017Rewiring trailer brakes, best place to ground them?Issues with the trailer brakes, going to rewire. 4 drums. Original setup has a set of two wires running to each drum. Going to run one Marine grade coated wires for 2 drums, instead of all 4. ...Show More
prichardsonExplorerNov 29, 2017The wiring diagram at the beginning is on the right track; however, the ground wire should go to the frame not the axle.
Related ContentBrake rewiringRewiring the brakesTrailer BrakesRewiring water heaterRewiring Trailer Brakes - How to Allow for Axle Movement?
