Buzzcut1 wrote:
Guys I'm just getting the Wheels from Rickson. The tires are coming from Les Schwab. The have "instock" 3-4 brands of 19.5s and I am still debating tread pattern but leaning towards a Toyo with a similar tred pattern and the same outer size profile as the tires I currently run
Your wheel and tire combination is going to weigh about 110-115 lbs. each.
My wheels and tires were balanced with lead weights, but I also purchased the Centramatic dynamic load balancers to keep those heavy tire and wheel combinations running smooth.
I had a set of Yokohama RY-023 tires that had excessive runout and never did get them to run smoothly. I had them adjusted to a set of Michelin XRV tires and they ran very smooth.
