The fact that you ran 35" tires in the past without clearance issues make these tires tempting for the additional height clearance and width. I hauled a 4000 lb camper while towing 8000 lbs, so I did not want to to go to taller tire than 33". Your loads are less, so the taller gears may not be an issue although you will find brakes will wear faster with taller tires. The sidewalls are rigid enough that you will not be complaining about flex, so that is not an issue. I ran the Visions on my Ford, but they seem to stick out on the Dodges more (mine put the tire even with the wheel well lip).
