EldIr wrote:
Nvr2loud wrote:
Forget the kit, just set-up your load properly, maintain the correct air pressure in the tires, and have your brake controller accessible in case of an emergency where you need to apply just the trailer brakes.
I would either run without the friction bar or with a sway-prevention hitch... sway 'reduction' scares me too much. Once there is enough force to overcome the friction bar, you are likely never getting control back again. When I get a slight sway, I adjust my driving and correct (a little gas applied, or a little bit of trailer braking applied)
X2^^^
I've towed my current 30' Jayco first with a 1/2 ton Burb and now with the 3/4, for around 4000 miles with no sway control and NO SWAY. This includes all manner of trucks and semis passing in either direction and a storm with 40mph crosswinds. I'm a firm believer that a properly set up rig should not sway.
If money wasn't an issue, I would go with a sway prevention hitch, but I'm perfectly comfortable towing the way I am.
I'll have to disagree some. Yes when setup correctly there will be no sway. But that is NOT what sway control is for. It is NOT to keep the TT inline in normal driving. Not even when trucks are passing. IF it sways in normal driving. Other problems need to be addressed. In other words. Sway control is NOT to prevent sway. Sway control is only to help control sway AFTER it begins
So you ask, If you normally have no sway. Why put on sway control? Well. Have you ever had to dodge a deer, dog, or child, or a car that turned in front of you., or veered into your lane unexpectedly. Blown a tire, Or well just a hundred things that can go wrong, and cause you to jerk the steering wheel to go around it? That is what sway control is for. To help dampen the movement of the trailer AFTER YOU have caused it to sway by inducing it thru the steering wheel.
I too have O sway. I can run easily down the road at any speed, be passed , and pass trucks. No sway. However. I put sway control on any way. Why? Well, there could be that deer, accident, or stupid driver just around the bend.
You can't always drive out of sway by speeding up. Especially if you are braking hard as you can, and you can't let off the TV brakes, and pull the TT brakes IF you really need to stop now. Or IF you have had to take to the median, or swerve off the road.
THAT is what sway control is for. Don't leave home with out it.
