Grit dog wrote:
Very little chance anything is worn out. Even moreso, that little camper isn’t even making that truck work very hard from a suspension and steering standpoint.
But many shops will tell you it is, unless they’re too busy to try to make some extra money on unnecessary parts.
Still gots to add more info and pictures or something if you’re looking for valid advice.
There's no way to know how OP drives or what kind of roads he drives on. Obviously, driving straight smooth roads will not be hard on the vehicle, but the opposite is also true. But, any good alignment shop will check for worn parts before they do an alignment.
The waste of money is aligning a suspension that has worn parts. The wear will continue.
Fwiw, pictures won't show worn parts unless they are extremely worn. Otherwise, it will have to be on a lift to look for movement.
