wing464 wrote:
I am reviewing the comments and I wonder if we are talking about the same material...I used the 3/4 in pink foam board that is used as insulation.. Put it in 3 summers ago and it is holding up fine with my Lance 981 Max... I did attach it to 1/4 inch plywood because I needed a comfort zone over the 5th wheel bed rails...The is very little compression etc with the material I used... Just Sayin
I used the same as you did, but 2-inch. I too have to go over 5th wheel bed rails. I did not use plywood between the foam and TC.
