SprinklerMan
Jun 24, 2014Explorer
Keith Haw wrote:BurbMan wrote:
CLICKY
Most ST tires are sub-par quality. Many of us with heavier trailers have upgraded to LT truck tires but that would require you to move to 16" rims and probably involve some suspension work since you have 14's now.
Don't want to hijack but, are LT tires safe for trailer use? If they are, that'll be my next tire set. Got to believe, after reading all the negative posts about ST's, that LT's are a better designed tire.
I have a 30 ft sunset creek that weighs 10000 lbs gross , in the owners manual they recommend either LT or St tires as long as they have the correct weight rating . ( Mine have 2000 lbs to spare ) I personally think that that would be a wise choice , others may disagree . But that is my opinion
44,068 PostsLatest Activity: Jun 19, 2026
