bighatnohorse
Nov 09, 2020Explorer II
Advice may vary as I've noticed that the Ram trucks seem to have a stiffer spring pack. (?) They don't sag as much as the Ford.
My truck is a Ford and I don't recommend the lower Stable Loads - I have them and they do little except to make a harder ride when empty.
I have added the SuperSprings - they reduce sag and allowed the truck air bag pressure to drop from 75 psi to 45 psi.
I have not yet installed the upper StableLoads - which is what I probably should have done in the beginning - the upper overload spring does not currently engage (unless hitting large dips in the road).
Upper StableLoads would definitely engage the upper overload springs (on Ford). Rams may be different.
I will remove the SuperSprings and install the upper StableLoads when time and opportunity presents.
44,070 PostsLatest Activity: Jul 21, 2026
