Grit_dog
Nov 09, 2020Trailblazer
covered wagon wrote:bighatnohorse wrote:
Those tires can be inflated anywhere from about 65 psi to 80 psi.
What psi do they have now? Have you experimented with changing tire pressure yet?
I've got the rears at 80 psi and the fronts at 70. It steers well, very straight when the surface is flat and not tilted.
Are there any good solutions to getting the overload springs back in action? Since putting on the airbags the rear is so well supported, but is not allowing use of the overload springs.
I am aware of using bump stops or supersprings on the overloads..... just wondering if anyone has a recommendation for either since one or the other might be a better option based on someone's experience.
There are many solutions. Start readin. It's discussed here regularly.
