HMS_Beagle
Apr 06, 2017Explorer II
A rigid frame does not make a sway bar more, or less, necessary, but it does make a sway bar more effective. A sway bar has two functions: 1) to control body lean and 2) to control the proportion of weight transfer (to the outside tires in a corner) between front and rear axle. The latter in particular becomes more problematic with a floppy frame, as it simply twists more than the sway bar.
Body lean is what most truck/camper owners want to control, but weight transfer can become important if for example a very stiff bar is put on the back keeping a weak one on the front. You may find unusual handling when running empty in that situation. It is best to upgrade both ends in somewhat equal amounts.
