CharlesinGA
Apr 12, 2021Explorer
otrfun wrote:
We chose the Roadmaster over the Hellwig for our Ram 3500 SRW because it mounted to the axle housing in a more outboard, OEM fashion, at the bottom of the shock mounts. The Hellwig mounts more inboard with a clamp around the axle making it less effective IMO. We also installed lower Stable Loads (stainless steel versions). They offered some improvement in sag, handling, and even reduced sway slightly (at highway speeds)—-nothing dramatic. They work especially well when used in conjunction with slightly pressurized airbags.
I bought a Hellwig for my '03 2500 RAM. I was not happy with the mounting setup to the axle, as it clamps right at the point the axle tubes go into the differential casting. The Roadmaster picks up the stock mounting points on the shock brackets, further out, so the bar does not need to be as thick to have the same effect.
The Hellwig has been sitting in the box for a couple of years now, I guess I ought to get rid of it.
Charles
