Gdetrailer
Feb 28, 2020Explorer III
Boomerweps wrote:Gdetrailer wrote:
Do be aware, the ball in your link is a 2" ball, not many TTs use a 2" ball, none of the TTs I have owned use that size..
The only application I have for that size is my Log splitter and I used it only once to tow from the store to my home..
Most TTs you will find use 2 5/16" balls..
Most single axle TTs & cargo trailers I've checked use a 2" at GTWR of 5K# & under. Dual axle, then you're right.
Do any new trailers of any kind still use a 1&7/8"? I still have a couple. Sorry for the sidetrack.
You might find 1 7/8" ball on small light weight boat trailers, small light weight landscape trailers..
2" might find that on some small "Uhaul" platforms and single axle trailers but once again, not all that common and is for very light weight applications.
IF you have a properly fitted hitch shank to receiver you should never feel any movement between the vehicle and trailer which would necessitate such a device that the OP linked to.
Now the ONLY caveat that I could think that this is aimed for would be in the case of a hitch with a surge brake system. There IS some "play" and MUST be some "play" which could cause hitch chucking (IE jerking).. However, I suspect by removing the play (with a rubber mounted ball which is going to move around) you will now reduce the effectiveness of the surge brake controller.. Surge brakes depend on some slack in the hitch system, the brake actuator is built into and part of the tongue and must have some slack to work correctly. That slack could cause some bumping or learching and that IS "normal".
It IS nothing more than a "solution" looking for an "application".
I would not waist the $50 on it, instead, replace all of the loose fitting hitch parts or in the case with a surge brake system, live with it or take the risk of the surge brakes not working as intended..
My question to the OP of WHY do YOU need it or want to know about it was not answered..
Are YOU experiencing learching?
Or do you feel that paying $50 for a "improved" device can make your towing experience better?
Sometimes folks think just because there is a more expensive devise that it MUST be better..
