- fj12ryderExplorer IIIInteresting, thanks.
- Deep_TraxExplorer
fj12ryder wrote:
The fender lights kind of make sense, but I'm actually referring to the lights on top of the cab. What the purpose of those?
I was referring roof clearance lights which are fairly common on 3/4 & 1 ton pick ups.
Here is plenty of reading on the subject if you want more:
purpose-lights-roof - fj12ryderExplorer IIIThe fender lights kind of make sense, but I'm actually referring to the lights on top of the cab. What the purpose of those?
- Deep_TraxExplorer
fj12ryder wrote:
AFATG I've never figured out why they put the lights on ton trucks anyway.
They seem to be common on trucks equipped with snow plow prep packages, I always guessed it was because a plow blade would block your traditional running/parking lights. Again, it is just a guess, but it makes sense to me. - spoon059Explorer III
tegu69 wrote:
I don't understand why you would want white lights, much less worry about them being seen in the daytime.
Good thing you aren't me, because you don't need to worry about it. What is the point of your post? - carringbExplorer
Required on vehicles over 80" wide i.e. Duallies and trucks like the Raptor - fj12ryderExplorer IIIAFATG I've never figured out why they put the lights on ton trucks anyway.
- tegu69ExplorerAmber clearance lights go on front and red clearance lights on rear. I don't understand why you would want white lights, much less worry about them being seen in the daytime.
- buc1980ExplorerI like the white led clearance light.I order Recon clear lens with Xenon gas 194 bulbs for 39$ from Amazon.I hope that that set up will change the appearance the way I like it.
- CampingN_C_ExplorerFunny I'm reading this, I just saw one last night and thought it looked good.
