RVcircus
Oct 20, 2014Explorer II
westend wrote:
I'd suggest you fill the "square" with material underneath the joint where the roof sheathing meet. I wouldn't use the air conditioner's fastening bolts because those are not typically tightened completely.
+1
I'd try to brace/support the entire opening around the AC unit along with anything else I could access from the 14"x14" opening. If you need to screw anything from the roof side patch with Eternabond tape and replace the AC gasket while you're at it.
44,066 PostsLatest Activity: Mar 14, 2015
