thib2722
Oct 21, 2014Explorer
It looks like they cut the AC hole through a joint of two pieces of plywood. It seems like they would not join sheets where they intend to put an opening. Structurally, it just seems like an awful idea. I would attempt to use something lightweight to reinforce the hole such as aluminum angle iron. It won't rust, and it's light enough to not cause any added weight. You you have to remove that AC unit to really see what's up under there. You'll need some help. When I removed mine, it was pretty heavy. It took one man on each side to lift it clear without doing any damage to the rubber roofing.
44,066 PostsLatest Activity: Mar 14, 2015
