deltamaster
Oct 22, 2014Explorer
Under the rubber membrane and over the existing sheathing... good idea. That should make sealing the topside much easier.
Did you apply adhesive before setting the new plywood? I would have applied adhesive to the repair patch before sliding it in place for added support and strength.
Do you plan to screw the patch to the roof sheathing from the underside?
These pictures are much more descriptive of the problem. Had they not cut that lare aluminum brace so far back you likely would not have had this problem. Should have left it overhang the joint a couple inches.
Good luck and I hope it works well for you.
44,066 PostsLatest Activity: Mar 14, 2015
