Tom_Orlowski
Mar 25, 2015Explorer
I just purchased a 2015 Adventurer 89RB this past fall. Before the cold wet weather I got up on the roof and applied 4" Eternabond to all of the seams created with installation of vents and sky lights. As well as the most forward seam were the front cap joins the roof. As stated preperation is key. I used denatured alcohol and a rag. Worked very well. This is my second rv using this same method with great results. The eteranbond tape applied to my 17 year old travel trailer 5 yrs ago has not lifted at all.If done properly with out short cutting you will not be disapointed. Good luck.
44,066 PostsLatest Activity: May 18, 2026
