falconbrother
Dec 10, 2019Explorer II
Don't use the stuff from Lowes unless you really don't care about keeping that RV. That stuff will work but, it's inferior to what's on your roof and what you should use. At the very least use EPDM liquid rubber or some other compliant product. I had a raggedy old motorhome that I was constantly fighting leaks with. I used that stuff from Lowes and it worked..but.. I had to reapply at least every year to keep the RV dry inside. Until it's completely and utterly dry it will turn back into goo when rained on. EPDM rubber can get rained on immediately and still seal. It's a totally different animal. It will seal when still tacky. Look up RV roof coatings. Also, take your time. Clean that roof like you were going to eat on it before putting anything on it.
I fought the leaky RV roof battle and it's no fun. Yours isn't leaking. You should be very thankful for that. Do everything you can to keep it that way. This is a scenario where an ounce of prevention is very much worth a pound of cure.
