RustyMacIntosh's avatar
RustyMacIntosh
Explorer II
Dec 09, 2019
Roof: Not leaking, but 20 yrs old
1999 Mallard 19ft travel trailer. I use it frequently. I was installing a rear camera when I got a closeup look at the roof. While it is not leaking, I got to thinking maybe it is time to shore it up,
Lowes/HomeDepot sell that while goop stuff that comes in a large can. Can I smear that stuff over the existing roof?
What about using something like FlexTape then smear the goop over the roof. Let's say around the edges, and near the AC and vents.
What suggestions on a better way or to proceed?
I am taking the trailer from CenCal to Kansas in or late mid-January 21 for some business with the courts, lawyers, trust,,,I sorta kinda would like the roof to be solid. I am sure I probably will encounter some rough weather while in Medicine Lodge. Luckily the Suburban tower is 4x4.
I just feel that after 20 years I might be well advised to treat the roof of the trailer before taking off.
  • I'd be more concerned about making sure it's caulked at every seam where water can enter.
  • 1. 20 years and no leaks you are very lucky
    2. While your roof may or may not be rubber, I would not use Lowes white Goop. I would use the more expensive RV rubber roof repair goop.
  • Have you maintained the seams on the sides? Windows, corners etc. for instance?
