Wo_ody
Jun 14, 2013Explorer
Roof splitter...better front end aerodynamics
Big beliver here of DIY aerodynamics.
The "pocket" in-between your TRUCK cab and camper cab-over is a huge source of drag and wind noise. Its like towing a parachute.
A roof "splitter" will lower drag and wind buffeting considerably and its easy to make. The idea is to create an inverted "V" shaped appliance which fills the "pocket" between your TRUCK cab roof and camper cab-over.
Cut a 10mm x 4' x 8' sheet of Coroplast corrugated plastic or a 1/8" x 4' x 8 sheet of FRP Panolam (Lowes) to a triangle shape. The base width equals the width of your camper...lets say 80". The point of the triangle extends from the front vertical camper wall forward to the leading edge of the TRUCK cab roof. Then semi-rigid polyethylene foam...such as a pool noodle...is attached to all 3 legs of the triangle. Attach a layer of foam above and below the sheet triangle so it sandwiches the perimeter. ***NOT AN ADVERTISEMENT, JUST AN EXAMPLE*** Sheet polyethylene could also be used and can be located from a supply house such as Foam N' More http://www.foamforyou.com/
The "splitter" is set on top of the TRUCK cab roof and the camper is lowered. The foam will compress to the shape of the roof and the bottom of the camper cab-over. The idea is to make the polyethylene foam thick enough so the "splitter" will stay in place by compression fit.
In my opinion, the reduction of wind buffeting alone is worth the cost.
