jdc1
May 14, 2020Explorer II
Pull the trailer wheel off. Remove cotter pin. Remove the large nut. Remove the drum. Look at the brake shoes. The brake material should be 3/8" thick. Any oil around the shock? 10k miles is nothing for a shock, unless you are doing the Baja 500 with your trailer.
