goducks10
May 15, 2020Explorer
His profile says he has an Outdoors RV TT. Shocks are part of a package along with 16" tires.
The shocks are not high quality but still should last more than 10,000 miles. Best way to check the shocks is to take them off and manually push on them. If they push real easy or even fairly easy then they're shot. You should have a hard time trying to compress them when they're good.
As for the brakes you have to remove the brake drum. Personally I wouldn't worry about the brakes after 10,000 miles. But I would be looking at doing a bearing repack after 2 years and 10,000 miles. Mainly because you don't know how well the factory packed them.
If you have the EZ lube axles and pumped in grease through them you may have blown a bearing seal which would spray grease on the brakes.
Time for a complete tear down and inspection.
