Mr__Bill_TT's avatar
Mr__Bill_TT
Rubber roof sealing
Ok now the rains are here and am finding small water leaks through rubber roof.
Way so many things available for sealing rubber roofs.
Any one has any recommendations?
I'm curious on the Henry's 887
Has anyone else used the product and can advise?
Thanks
  • gbopp wrote:
    Eternabond, Dicor Self Leveling Lap Sealant and Heng's Rubber Roof Coating do the job for me.
    This exactly how I've cared for my 15 year old rubber roof. Never leaked.
  • I use Eternabond, Dicor Self Leveling Lap Sealant and Heng's Rubber Roof Coating.
  • The rubber membrain itself doesnt leak unless it is totally worn out or damaged. What you have is a seam or opening leak. Right now there is nothing you can do. You need to either move the RV under cover, cover it or somehow get it dry. Once dry you can inspect and seal openings.
    These are the things that are recommended by the manufacturer of your roof and are commonly used by the members of this forum.
    Other things may seem to work for a while and then fail prematurely.
  • Eternabond, Dicor Self Leveling Lap Sealant and Heng's Rubber Roof Coating do the job for me.
