hohenwald48 wrote:
colliehauler wrote:
hohenwald48 wrote:
2oldman wrote:
cbwallace wrote:
Additionally, CO2 is heavier than air so using the setup described over night would dump a lot of CO2 right under the front of the trailer where you are sleeping. CO2 detectors help, but mine is located in the back half of the trailer by my fridge and furnace. Not sure it is worth the risk.
You are probably referring to CO, not CO2. CO is slightly LIGHTER than air.
And yes, OP does not want to be sleeping with a gigantic CO generator a few feet away.
Motorhomer's do it every night. And in most cases those generators exhaust out below the belly of the motorhome. But it's a decision each individual has to make on their own.
Motorhome and toy haulers have a exhaust that vents out the side not under the belly. They also have a fan for cooling that draws in air and exits out beside the exhaust pipe.
Well, I'm not sure what kind of motorhomes you had but all 6 of the ones I had vented below the belly pan on the driver side.
All 5 of my Onans vented the exhaust to the side of the RV, not underneath the RV. The tailpipe comes out from the bottom of the RV and exits to the side, not under the RV.
