babamartha's avatar
babamartha
Running a/c on house current
I'm told that my Kodiak 160SVT a/c should be able to run on household current. It's plugged in via extension cord to an outside outlet. My microwave only works on 30 amps and so I'm thinking the same is true of my a/c. What's the truth?
My household a/c is down and I'm wondering if I can just sleep in my camper. We're in a heat wave here in Maryland.
  • Plus the typical 15A household plug is one of several on the circuit. Meaning other househould loads on that circuit need to be considered.
  • babamartha wrote:
    My extension cord is one of those orange 25' jobs.
    It could be 16ga (small) and even aluminum wire. Get at least 12ga if not 10ga.
  • I spent a week in my fiver with the 15k ac running off a regular, household outlet..
    I just ran my 50 amp cord to the outlet and use a 50-30 reducer plugged into a 30 to 110 reducer.
  • I know it's a little late right now, but for future reference, have an electrician run you a dedicated 30 amp receptacle, i did, and it is well worth it, I would have done it myself but I'm not all that comfy working with electrical.
  • a 25foot heavy duty extension cord is not that expensive
    frying your hvac unit due to low voltage will be much more expensive
    be safe and purchase a heavy duty cord
  • Hi BabaMartha,
    It would be best to use a heavy duty cord, and do monitor the voltage. If it drops below 107, then it may be best to not use the air conditioner.
    Most (almost all) 13,500 BTU a/c's will run off a 15 amp circuit, but that's all........make sure you don't use anything else in the TT. Use at least a 10 gauge ext cord if you have to but better yet, use a 30 to 15 amp adapter and plug the TT cord directly into the outlet.
    No harm in trying to see if the circuit will support the ac.
  • If everything else electrical is off you should be able to run your A/C. However, use a heavy duty extension cord if you need more length. No “truth” issue here. Just a different view. Consider reading about basic RV electricity online. Determining what each item needs to start and then to run is easy to learn.
