Straight out of a fridge manual.......
Leveling is one of the requirements for proper operation of absorption refrigerators. The absorption design utilizes no mechanical pumps or compressors to circulate the refrigerant within the system, so proper leveling must be maintained to provide the correct refrigerant flow.
Without proper leveling, refrigerant within the cooling unit will
collect and stagnate at certain areas.
Without proper refrigerant flow, the cooling process will stop.
When the vehicle is moving, leveling is not critical as the rolling and pitching movement of the vehicle will pass to either side of level, keeping the refrigerant from accumulating in the piping
