time2roll
Apr 29, 2018Nomad
Primary concern would be overheating the furnace fire box. There is a high limit switch that will cycle the burner while the fan continues to run and blow air. If you notice the burner cycling, maybe every two minutes, I do not recommend running the furnace with the restricted air flow. Need the slide out or add some additional unrestricted ducting.
