hddecker
Sep 15, 2014Explorer
anaro wrote:
Yes you can unplug and blow on the connections and try plugging in again. Then test the output from the truck to see if you have power coming out at the pig tail receiver (7 pin connector) if you have power coming out for all pins then the fuse or tv is not the issue. Then you need to be looking at the tt.
Isn't there a ground in there? I think you only have power six terminals. http://rvbasics.com/techtips/rv-travel-trailer-plug-wiring.html
How long have the lights been out? This should have been caught as soon as it happened. Just because you usually tow during the day doesn't preclude you from doing a pre-trip every morning.
I'm sure the CVS would just love to have you roll up to a safety check.
Maybe you would like to refresh your knowledge of the "towing a trailer" handbook, before it costs you dollars, points, increased insurance.
44,066 PostsLatest Activity: Apr 10, 2026
