nineoaks2004
Jun 18, 2016Explorer
120 V does not usually use fuses, it uses breakers so if it does trip and you cannot run it,and want the 110V outside plug all you have to do is re-set the breaker. You should have no problem with it tho. as they are very low amp units.
44,066 PostsLatest Activity: Apr 10, 2026
