- spoon059Explorer IIDepends upon how much other stuff is running at the same time. Provided you aren't overloading your circuit, it should be fine. My trailer came with an outdoor kitchen and an electric outdoor fridge. With 30 amps and sufficient voltage I can run my AC, indoor fridge, outdoor fridge and electric water heater at the same time for less than 22 amps.
- Mark_and_LindaExplorerShould not be a problem....I run my shop vac off of mine. I have seen many others with an ice maker on theirs.
- nineoaks2004Explorer120 V does not usually use fuses, it uses breakers so if it does trip and you cannot run it,and want the 110V outside plug all you have to do is re-set the breaker. You should have no problem with it tho. as they are very low amp units.
- downtheroadExplorerNo problem.. (of course you have to be hooked up to shore power or running a generator).
You probably have 30 amps to work with. Mini frig. draws very few of them.
44,052 PostsLatest Activity: Nov 23, 2025
